XF Battery Drain.
Hi everyone.
Ive has my XF for about 6 months and love it. Unfortunately I seemed to have been struck down with a battery drain issue.
Something is pulling about 6A constantly from the battery. I’ve put an amp meter across the battery in series and pulled every fuse but nothing seems to curb this extraordinary battery drain. The car needs jump started every day.
The battery has had been replaced and holds it charge if disconnected and when running there is plenty coming from the alternator so can rule out these things I think.
Can anyone with any knowledge possibly help and point me in the right direction?
Other problems to be tackled are for future posts.
Thanks everyone.
Thanks everyone.
Thanks for your quick reply! Do you happen to know which relay is the starter relay? I can’t find out anywhere which relay is which.
A much more common problem on the S-Type than the XF, although time will tell as these age. Try the methods in this thread and attachment, seems to help a lot of people.
https://www.jaguarforums.com/forum/s...-drain-123535/
Boomer from Boston
06-09-2024 05:06 PM
