XF drivers heated seat not working
Hi my first post here and looking for some advice with a heated seat problem as my drivers seat heat is not working. I have check the fuse which is fine and the passenger seat heat also works as does the cooling fan on both driver and passenger. I have also had the seat up and all the wires look fine with no brakes, so reading other posts it looks like it's either the heating elements or control module. So my question is how can I test these to see where the fault is? Thanks in advance and apologies my first post was asking for advice
Welcome to the forum Thefinn,
I've moved your question from X260 to X250 forum. X260 is the current model from 2015 onwards. Members here with the same model as you have will be able to help.
o2manyfish
11-11-2016 01:03 PM
