XF Ground wires
I have tackled many projects on my XF S/C from removing the supercharger in order to change the dreaded hose most already know about. Meddled with both water pump and aux coolant pump. I've recently been dealing with the EGR valve. Lots of cleaning done with all projects as they collect dust these V8's..One thing that has become the main thing with most of the issues i've had is down to bad contacts with GROUND wires. Remove when can and clean well. Hope this helps. I can help with some locations of if needed..
