XF Light knocking sound at 1st Start
Guest
Posts: n/a
Just recently I have been hearing a light knocking sound when I start my XF in the morning. It only happens when the car is changing from 1st to 2nd gear, and it only does it 1 time after 1st start of the day. I also happens after the car has been sitting for a couple of hours. The only consistent thing is that the light klunking sound is happen when the transmission is going from 1st to 2nd gear. any one heard of this a or have an idea what that maybe?
Guest
Posts: n/a
I had if for five months, only 1700 miles. Not the kind of knock from cheap gas. It only happens once, and that when it goes from 1st to 2nd gear after initial start of the day. After that the noise never happens again. once a reach my destination and after the car cools down for a few hours, but it only does it once after the start up while going from 1st to 2nd gear. After that the car operate normal. It almost sound like some belt, drive or something going on with the transmission. I do notice that when the car is going from 1st to 2nd there is sort of a strain and slight going from 1st to 2nd gear. Yesterday the check engine light came on, I wonder if the knocking and the check engine light are related???
My lincoln towncar used todo this. The whole day the car was fine, but in the morning, shifting upwards for the first time in the daywould cause a knock sound. My problem was gunk in the tranny line as well as neglect of tuneup. I can not possibly think what yor brand new XF would have faulty. Hope my advice helps.
i think my XF is doing the same thing.. One single muffled "clunk", coming from the rear as you first drive-off in the morning, at about 10mph, right?
All this time i've assumed that was the truck auto-locking (or something locking) - could that be the sound?
Randy,
Any update on your single clunk?
My car does the same thing. I normally nose the car into my garage. I have to back it out and then go in reverse down the driveway. I hear the clunk once I put it in Drive and pick up a little speed. like you say about 10 miles an hour.
No update.. it doesnt really bother me that much..
I also nose my car in and reverse down the driveway, which is on a downhill.. i have noticed that the clunk does correspond with changing into 2nd gear.. tomorrow morning i will try to remember to put it into sport-mode which will delay the shift a bit, to see if it still does it right at the shift, or if it's related to the speed..
This morning after backing down the driveway i shifted to S instead of D.. The knock occurred at the exact same speed as usual, ~10MPH, but because I was in S, i didnt hit 2nd gear until 20MPH or so.. so, it appears it is not directly related to shifting into 2nd gear, more related ot the speed or distance traveled.
Guest
Posts: n/a
Based on the description, it seems to me the knocking sound is due to ABS kicks-in. Each time when you start the car, the ABS will do a self-test and when ABS kicks-in at the car speedbetween 15kph - 20kph, you will hear a slight knocking sound (sometimes louder, sometimes softer). I have same situation for my XF. My previous MazdaRX8 also have similar knocking sound when ABS kicks-in.My friend who drove Auditold me his similar "problem". Seems thatthis is normal. However, what I don't understand why some other cars such as BMW or Mercedes do not have this knocking sound when ABS kicks-in. I was told that you can eliminate this knocking sound by removing the ABS fuse at the electrical box. But by doing so, you have disabled your ABS. There will be a ABS warning light at your dashboard lighted up.
I'll be darn..I bet that is it then..I never thought of that..but I know what it's all about..My Hummer does that too for the ABS system, same way...But sounds more like a little relay chatter for a second...The discription of a Knocking sound coming from the engine, had me thinking in another direction.
