XF - Lowering rear windows
Received 3,225 Likes
Well, yes, it might be and it was, since just looking at the window and the door should give the obvious answer. If the window is larger than the cavity in the door (which is very common in 4 door sedans, and true in this case) then it can only go down until it runs out of room.
