XF park brake
Mine does this also. It is a bit weird but most if not all automatics move to some degree when park is selected and the brake released. I tend o set the parking brake first, then P and then release the footbrake. Otherwise the transmission park brake pings alarmingly if I am parked on a steep grade when I restart and drive off, particularly if parked facing uphill.
The park brake is usually a mechanical pawl inside the transmission tailshaft housing.
When you say "selected Park" it sounds like you mean you turned the rotary gear selector (PRNDS) to P. If this is what you mean, it has nothing to do with the electric parking brake and your transmission may be on its way to a painful death. This would account for the rollback also if the parking brake was unused and you are making the transmission pawl hold all the weight. The parking brake control is the shiny silver lever that is rearmost of all the controls on the center console between the front seats. Simply lift this lever to apply the brake and a light will come on in the instruments. You don't have to do anything to release the brake, simply drive away from a stop and it will release and the light will go out.
neruda
10-18-2015 01:19 PM
Pluckie
10-03-2015 07:57 AM
