XF Performance Specs (All Model Years)
Gathered some info on the XF. Please realize that there are so many factors that affect times. I've tried to use mostly manufacturer numbers to be fair and for a better comparison. At least these numbers are somewhat standardized compared with other things like weather (temperature, humidity, barometric pressure), altitude, traction control settings, etc. that can grossly vary from the magazines. Hope someone finds it useful.
The following 5 users liked this post by Macedon:
BritCars (03-30-2014),
drsn97um (05-20-2014),
John Fox (03-30-2014),
MrChuckles (03-30-2014),
UltBlkXF (03-30-2014)
Thanks for posting! Ironically I was just going to look this up this morning as I went to the track and was curious what the published times were to compare...
Last year I ran a 12.9 just as the spec indicates. Ran 12.6 this year -- temp was in mid 60s, low humidity, etc so that probably had a lot to do w/ it... ( I have XF-S BTW -- which I still don't believe only has 470HP as this thing is FAST!!)
I realize that different publications will get different results. That's why I went with Jaguar's quoted numbers. At least these numbers should be consistent when comparing XF to XF.
In the instance of the 2013 2.0t XF:
- Edmunds.com 0-60 mph: 8 sec
- Jaguar 0-60 mph: 7.5 sec
- Car & Driver 0-60 mph: 6.8 sec
Here's another performance update. This dyno sheet was taken from a press release for the F-Type, but they use the same AJ126 340 hp/332 lb-ft V6 base engine as the V6 XF. The F-Type S achieves its 380 hp/339 lb-ft number using the same V6 engine via a bump in boost from 25.4 psi to 27.6 psi.
scottatl
09-04-2015 08:08 PM
FS[Canada]: Vancouver BC FType lease takeover
nd143
09-03-2015 04:42 PM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
