XF restricted performance and eml - sorry, I'm a newbie!
Hi all, yes I'm a newbie, not to forums but to this one yes.
Recently bought my first jag having owned mercs and saabs in the main and i do like it but today, i hate it !
Its a 2008 2.7d with 70k on it. When I bought it it had only about 200 miles since service and mot in march. I have put abot 250m on it.
Drove to work today and after a mile the rp triangle kept flickering on and off, csr was driving fine and it cleared.
Coming home again a mile in same thing then eml came on. And has stayed on, won't clear after three re starts. The rp light flickered on then went off.
Now I was low on fuel yesterday and put bp ultimate diesel in it. Not saying that's it but I'm a bit stuck. Any ideas ?
Received 3,915 Likes
Callan, before we can provide some useful information, we ask that you get the codes read on the car. This will give us a starting point as to what is wrong with the car. Your problem could be something as simple as bad fuel, but could be a high pressure fuel pump, failing MAF sensor, etc. Once you get the code(s), post them here (just the letter and 4 digits). I say to only give us the 5 character code as some readers do not give the correct interpretation of the code as it relates to a Jag and I would hate to start off with people being misled.
Grant Francis (07-26-2020)
check for corrode wires ,,passenger side fuse box on side wall,, i am having the same problem,, found them after 2 high pressure fuel pumps, 1 fuel filter, 1 map sensor,1 maf sensor,1 fuel sensor, later because none of that fixed my problem,, now im hunting down terminal pin,and new connector box,,5 wires terminals corrode bad, hope the best for you
TraxtarXKR
11-13-2019 12:51 PM
powerhouse
08-29-2014 02:10 PM
