XF Speed Limiter?
XF Speed Limiter?
I have a 2012 XF Portfolio and am curious to know if it has a speed limiter. I know some cars are speed limited to the tire speed rating. Don't plan to find out for myself. When I bought the car the dealer swapped the standard wheels/tires for the 19" Aquilla wheels with Pirelli P Zero A/S tires but if there is a limiter I guess it would be set for the standard Continentals.
I can verify the speed limiter is set at 200 km/hr indicated (around 195 actual). I refer to this as Italian cruise control: you just put your foot flat on the floor and steer. The nice thing is the speed stays rock solid at the limiter because it is electronic throttle controlled so seamless to the driver, uphill downhill and round the bend the speedometer needle stays at 200 indicated. Marvelous.
flyjag (01-22-2013)
Jaguar Forums Editor
Jaguar Press release
09-25-2015 12:58 PM
