XF Transmission
Guest
Posts: n/a
From time to time when the XF is in automatic transmission mode it will spontaneously change to Sport Mode.
When this happens I hold down on the right paddle and it goes back to normal automatic transmission mode.
Sometimes when this happens I first upshift and then go to automatic transmission mode.
I have brought the car to the dealer but since the problem is intermittent I can't recreate it.
I've noticed that it generally happens when I'm driving at a very low speed either after parking or after stopping at a red light.
The problem is not caused by my pushing the right paddle inadvertently. When I drive my hands are nowhere near the right paddle.
In the last month I've been driving with the Winter Mode turned on.
I've noticed during that period there has been no spontaneous change to Sport Mode.
That's the only new anecdotal piece of information that I have.
My tech has told me that the XF has the same transmission as the XK so an XK owner may also have information.
Why am I having this spontaneous problem
What is the fix?
Thanks for your help.
Donald Baraf
What is the fix?
Donald Baraf
Received 2,192 Likes
IDE THROW NEED PADDLES AT IT, ESPECIALLY INERMITTENT. HAVE HAD ON XK'S BEFORE, THEYRE RELATIVELY CHEAP TO JAG, ITS A LIKELY CAUSE, AND AS LONG AS YOURE AWARE YOUR NOT TOUCHING THEM( WE DO HAVE CUSTOMERS DOING IT WITHOUT REALIZING IT) AND IVE DONE IT BEFORE ON TEST DRIVES, ESPECIALLY SINCE IM A FINGER TURNER(SPIN THE WHEEL WITH MY FINGERS)
BRUTALS in the right ballpark I think. Make sure you aren't inadvertantly touching the left paddle for downshift as that will automatically put the trans in sport. Selecting the WINTER mode automatically cancels any manual shifting or sport mode and that would explain the "FIX" when winter is selected. Just some double checks before a tech puts paddles in and you have the same problem.
Guest
Posts: n/a
Thanks for your interest and your prompt replies.
What does "IDE THROW NEED PADDLES AT IT" mean?
I know that I'm not touching the paddles- when I drive I'm nowhere near them and I'm not well aware to stay as far away as possible.
The override works.
What do I do to fix the problem when I'm not in override?
I had 3 S types and they had no paddles.
Donald Baraf
The override works.
Donald Baraf
Paddles have nothing to do with Sport mode. The Sport mode is selected only by the rotary dial. I have noticed that the "detent' action on my selector dial is a bit loose and it is easy to slip the tranny into Sport mode when selecting Drive.
The paddles only shift the transmission, they do not engage Sport mode. The difference between Sport mode and Drive mode when you operate the paddles is in Drive the transmission reverts to full auto mode after 30 seconds or so of not shifting, no acceleration, braking or cornering. In Sport mode the paddle activation locks the transmission in manual shift mode regardless of acceleration, braking, cornering or time elapsed..
Holding the upshift paddle (right hand paddle) for 2 seconds continuously while in Drive restores full automatic Drive mode. Doing the same while in Sport mode restores full automatic Sport mode.
Regardless of Drive or Sport selection and regardless of any paddle commands, the transmission will always upshift at redline (at the latest) and will always downshift if the revs drop too low, UNLESS winter mode is engaged in which case first gear is locked out of automatic function and can only be manually selected with the downshift paddle.
If your transmission is selecting Sport mode intermittently this cannot be connected to the paddles but might be connected to the rotary dial shifter.
ORIGINAL: jagular
Guest
Posts: n/a
When I am in D and driving at a low speed all of a sudden the car will not shift from 1 to 2 and I notice on the panel that the numbers 1, 2,3, etc are displayed. The way I upshift is with the paddles. Since I haven't touched the paddles when I'm in D mode this is spontaneous. It's possible that this is caused by a loose paddle. Is this a known a issue? Has Jaguar seen this with other XF or XK cars? My Jaguar dealer called his Jaguar central office contact and they didn't give him any information. The more information I can give him the more help he'll give me.
He's a very responsive and cooperative guy but he's unfamiliar with the problem.
Thanks.
Thanks.
baraf the paddles are nothing more than small microswitches, and the wiring can be either chaffed of pinched in the wheel, Ive seen both on the same car. Chaffed on the 1st repair, and pinched on the 2nd(oops)....And the paddles simply unscrew from the wheel, remove air bag, wheel and replace switches, about 15 minutes, Thats why I dont see it as such a big deal for a tech to do...Unless maybe youre going to a dealer that makes techs buy anything they put on that doesnt fix a car(sometimes you have to replace a part as part of diag, not to throw parts at a car, but a logical thought process of fault and most likely reason) if this is the case good luck with ever fixing a intermittent problem.....
Once again I find myself agreeing with BRUTAL, I don't understand why they just don't put a pair of paddles on the car and see what happens or at least pull the wheel apart and verify no damage to the wiring. The wiring is tight and short for those steering wheel switches and paddles and I could easily see a problem developing there.
YOU GUYS, WE AT DEALERS ARE NOT ALL MORONS, AND WE DO WANT TO FIX CARS, JUST SOMETIMES THINGS DONT HOLD UP THEIR HAND A SAY HEY ITS ME! BUT A GOOD THOUGHT PROCESS AND A DEALERSHIPS MANAGEMENT THAT WANTS THE SAME THING TOO IS NECCESSARY. IVE PUT PARTS IN AND TOLD THE CUSTOMER, "I DNOT KNOW IF THIS WILL FIX, BUT ITS LIKELY, LETS SEE WHAT HAPPENS A GO FROM THERE" I MEEN YOU GO TO THE DOCTOR AND THEY SAY THE SAME THING, "TAKE THIS PERSCRIPTION, LETS SEE HOW YOU DO AND IF THAT DOESNT GET IT WE'LL GO FROM THERE" THATS WHY DOCTORS CALL IT A PRACTICE
. YOU USE SOUND JUDGEMENT AND INFO, UNFORTUNATLY SOME DEALERS ARE LIKE BAD HMO'S
That one isn't going in my notebook....
It's going on my wall.
And it's the same sort of battle with customer pay work, sometimes I have to err on the side of caution and not replace an expensive componentwhich I cannot definitely condemn. I eat the time, and the customer thinks he has to find someone more capable to correct his problem. So they surrender a stack of cash to someone more adept at taking it, often times with no other result. I never used to get chargebacks for warranty work, and I sure can't afford it on my own dime either.
BRUTAL and R_Tboth have the right attitude, you can't turn to the owner of a new car and say that you couldn't find the problem so you didn't do anything to try to correct it.Keep paddling.
Marka
22
09-11-2016 12:09 AM
dmatthewman
09-30-2015 10:10 AM
