XFR 155mph Speed Limiter - is it really there?
Are you saying that the accuracy of the VSS is true and the error is induced solely by the needle reading (inherent to the gauge itself)?
Yes.
The limiter (if it exists and if it works) would be calibrated on engine speed and wheel rotation. Speedometers are calibrated deliberately to over read to avoid litigation on speeding cases. You can check easily using a RaceLogic box or even a Garmin nav system. The speedo says 80 and the gps based system will tell you 76. and the margin increases the higher the speed.
Of all the countries in the world (except Switzerland) removing the speed limiter in the US makes absolutely no sense at all. There's no practical value nor is there any marketing value. Even if YOU can drive at 155 safely, most North Americans are so dumb at driving over 55 that you're essentially asking to commit suicide at that speed. They never look in their mirrors, type txt messages, sit in the left lane grazing on burgers and fries, while doing their nails, and answering the phone. If you want to try 155 or more with that going on around you, you're welcome!
mitch.thompson (02-02-2011)
However, this is very doubtful. More than likely the error is within the VSS itself - it is sending the speed to be 170mph when in fact the radar speed (or GPS) verified speed is really 157mph or whatever. In that case the limiter would be set to 170mph (kicks in when VSS = 170mph).
There was more to go from 170 but then again at 4200 ft above sea level and running out of road as well. I think gearing wise the car can do 180 tops thats 6th gear at full 6500 rpm. The hp is there the gearing is the limiting factor.
FYI there is no speedo calibration factor or error calibration. All Stalker DS2's used on police vehicles now a days are dead-on-***** accurate. By policy they have to be tested before shift and after shift to ensure calibration. Also after every citation issued for speed it must me tested. The 5 to 10 miles is a leeway given by the officer.
Hi, just to share, my stock XFR (5.0) does not seem to be limited.
I had a recent run up a highway, and hit 265+kmh (165mph) before being impeeded by a vehicle.
Seems like the car can probably go beyond the 270kmh maximum reading on my speedo, as it was still pulling strongly despite a very slight incline. If I had to predict, the max speed would probably be about 290-300kmh on a flat road, but will need a GPS reading to confirm that. Dynamic mode was enabled, but wasn't in sports mode on the autoshifter.
Fyi, the car was still very stable. It is such a lovely car to drive!
I have the video of the speedo hitting the speed, but was advised not to post it publicly... (don't worry, the wife was recording it... )
#30
Beyond that, all I can say is LUCKY YOU!!!
Cheers,
#31
aliensporez (05-20-2014)
#32
#33
Had a 2010 XF Supercharged before, never had an opportunity to test top speed. Traded it in a few months ago for a 2012 XFR. I have confirmed it will go 161 even though limiter is supposed to be set at 155. It was pulling very hard at 161 too. Speed pack raises it to 174 to my knowledge. A friend of mine who races jags in Canada says XFR they will do 201-202 with no restrictor. It's all about the tires and aero when you go over 186.
#35
Thang Nguyen
10-12-2015 02:25 AM
JimC64
10-11-2015 10:04 PM
hen555
09-08-2015 12:13 AM
