Xfr s/c 5.0 engines that are blowing
#101
I understand that Audi may have similar issues.
It all boils down to the manufacturers using low compression piston rings to increase mileage.
#102
#103
Wouldn’t it be simpler if your Jaguar flashed your oil level for a few seconds whenever you started your car on level ground? My 2011 XJ has 91,000 miles on it and I do the oil changes. Around 60,000 miles I changed the oil and made sure it was at the full mark. No surprise since I put in 8.75 liters of Jaguar oil with a filter. A week later I checked the oil level and it was down 3 liters? I checked it again a few times to confirm it wasn’t a bad sensor. I put one liter in at a time and waited until it read full. It took 3. If I would have had someone else do the oil change, I would have blamed them for under filling the oil. I ended up cleaning the manifold and the crankcase valve ( pretty clogged up) The issue never happened again 30,000 miles later. I have no idea where that oil went? I pulled the bottom pans and the only leak was the rear main seal , which I had replaced at 80,000 miles.
#104
#105
I do the vacuum method. I purchase the oil from my local Jaguar dealer @ $8.75 liter, but I buy my oil filters online via Reno Jaguar. The local independent Jaguar service center uses Motul oil.
#106
That is partly correct; the system will not give any reading until the oil has fully drained back, but does work on a stone cold engine, giving a reading around 3/4 along the bar & showing OIL LEVEL OK, when doing it according to the instructions would show the whole bar; presumably because the oil expands when it's warm, giving a higher reading.
#107
#108
The rationalisation is simple enough:-
Jaguar the car; the best value available, new or used, and in all important respects superior to any other manufacturer's product. It does what I want perfectly.
Jaguar the animal; quite different from the scummy creatures kept by some sub humans in order to annoy their neighbours.
For the record; I did not suggest that we should "go around shooting cats", but that shooting trespassing cats in the back of the head would prevent them from further damaging one's property; not the same.
#109
I had the same problem with a Lotus Super 7! It ran a modified Ford Cortina engine and I spun a rod bearing racing a Porshe on a slolom course. The engine was oil-starved, but only on hard turns in one direction. The solution was to go dry sump or install baffles. I did neither, just stopped racing it.😢
