XFR vs XFR-S Exhaust
Old 08-24-2018, 07:06 PM
hendogg8's Avatar
Thanks for the updates. Very curious how the outcome will sound. How were you able to order the center exhaust from the dealer? I heard they require a XFR-S VIN to order parts.
Do you have the valves deleted on your mufflers?
You can celebrate with some Suntory when it's all finished.
IppoJ (08-27-2018)
Old 08-26-2018, 12:42 PM
10 XF Premium's Avatar
Here is a pic of a 2013 stock center section of my base XF V8 Supercharged.
Slip fit to the rear pipes
Staggered “V” band (kind of) from downpipes
The following 2 users liked this post by 10 XF Premium:
IppoJ (08-27-2018), Panthro (11-24-2018)
Old 08-27-2018, 07:24 AM
IppoJ's Avatar
Originally Posted by hendogg8
Thanks for the updates...
I don't have the valves deleted, what I'd like to do is see if I can make them so I an open/close them manually.
That Suntory is fantastic by the way. : )
Old 08-27-2018, 04:58 PM
BritCars's Avatar
Search around on here. I'm pretty sure someone did that a few years ago. They cut out the valve and put in an open / closing valve with control switch on the dash so they could decide when to be noisy
IppoJ (09-06-2018)
Old 09-20-2018, 12:01 PM
IppoJ's Avatar
Sidebar: does anyone know if the rear cans on the XF are stainless steel or aluminized steel?
Old 09-20-2018, 03:09 PM
Stainless.
IppoJ (09-26-2018)
Old 10-09-2018, 08:20 AM
IppoJ's Avatar
Follow up Follow up, aka update.
Had a shop bolt in the XFR-S center section.
Sound is not really louder, per se, but marginally better. A bit more growly and more defined is the best I can describe it.
Roll off pops are much less tinny sounding and every once in a while one seems to be especially boomy.
Zero cabin resonance.
It's been raining non-stop so I haven't been able to really test any power or response gain from the x-over section.
The following 2 users liked this post by IppoJ:
hendogg8 (10-10-2018), Panthro (11-24-2018)
  #28
Old 10-12-2018, 01:38 PM
IppoJ's Avatar
Thumbs up
Sorry for the string of updates, can't figure out how to edit my last post.
It must've broken in over the past days because it really sounds good now. Not loud, doesn't drone but all of the good that was there before is easier to hear. Growly but not boomy. 10 10 recommend.
Old 10-12-2018, 02:31 PM
hendogg8's Avatar
That's exactly what I wanted to hear, growly but not boomy. Any chance you can upload a video clip?
  #30
Old 10-15-2018, 02:12 PM
IppoJ's Avatar
I'll try and get that tonight.
Yes, the only thing I've changed is that I swapped in the XFR-S center section with the x-over.
  #31
Old 10-19-2018, 11:12 AM
IppoJ's Avatar
...Any chance you can upload a video clip?
Sorry, I've tried twice to get a decent audio recording. No luck, for some reason.
boiler
US Southwest
10-17-2015 09:35 PM
damienedwards
10-03-2015 02:47 PM
XJ8JR
10-02-2015 12:13 AM
baskervillema
10-01-2015 06:43 PM
Quick Reply: XFR vs XFR-S Exhaust
