?? for you guys with the wrinkled dash
2011 XF
Bubbled dash showed up the other week. Just a short wrinkle in front of the speedo hump on the driver side. And a very small wrinkle over by the center speaker.
Question is.....
Will this get progressively worse?
Did it start small and spread?
I am thinking I should wait for the problem to spread before I tear it all apart...
Question is.....
I'm not sure if you saw my response to the visitor message about this issue you put under my profile so here it is again:
I used this shop to fix my dash:
A & T Upholstery
8579 Jefferson Hwy
Maple Grove, MN 55369
(763) 541-1968
It's kind of a mom and pop type of shop. It doesn't look that great from the outside. In my opinion I don't think they would take the car and pull the dash for you. You could always ask though. I brought them just the dash and the leather already pulled off. All they had to do was clean it up and glue it down. I'd let them pull the leather off if I did it again. Then you don't have to worry about the leather shrinking. Any shop should be able to glue the material back down so I would call around. It depends on if you want them to pull the dash as well. I'd bet most will shy away from that.
If you want me to pull the dash for you so you can bring it to an upholstery shop we could probably work something out. I could drive out to you so your car is sitting at your place while the dash is getting fixed.
A & T Upholstery
8579 Jefferson Hwy
(763) 541-1968
A & T Upholstery
8579 Jefferson Hwy
(763) 541-1968
A & T Upholstery
8579 Jefferson Hwy
(763) 541-1968
But, should I wait until more of the leather releases, or go ahead now, since it has just shown the first sign of failure? good winter project I suppose....
Short answer... yes it will get progressively worse, to the point that you have large sections of dash just "bubbling" up with leather pulling away from the speaker area.
I was able to convince Jag to replace my dash under the CPO warranty, but I had to pay $700 or so for the labor...
Cheers, Will
Cheers, Will
It really isn't bad. Watch that short Youtube removal video and it will help you get started. Take pictures of every bolt and lay them out on the ground in order of removal. Get good pictures of each connector as well but you can't really screw up the connectors since they aren't interchangeable. Nothing complicated about removing the torx bolts. It's fairly easy to find each one. Getting the dash out of the car after all the bolts are out is probably the most difficult part but should be easy with two people to guide it out. It took me 45 mins.
wesmc (09-09-2019)
unfortunately, the dash does not have to come out for the air bag, i just got my airbag replaced and the dash is the same
