ZF 6HP Shift Flare/Slipping
Hey.
My 2010 XF 3.0D S is having these weird upshifts from 2-3 sometimes. I have researched abit and i think its called "shift flare" or something like that. It doesnt happen often but its always the same gear that does it, if that makes sense. The transmission has been serviced 3 months ago. Does anyone know why this is happening? Like i said it doesnt happen that often, it happens kinda randomly. Thanks!
195.000KM (121.000 miles)
Hey. On the papers i got from them it says "Deep clean, change transmission oil" and they used SP Matic 4026, i live in norway btw. They also used "BG Transmission Servicekit"
It looks like the Kroon Oil tranny fluid should be OK, it has ZF 6sp specs but JLR can be pretty picky about fluids. I prefer Red Line. In general, “flushing” a tranny can cause problems and my mechanics don’t recommend it. I usually do a drop and fill which retains some of the old fluid and keeps the used tranny happy. I’d call your mechanic back and ask them to check it out.
I will call my mechanic and have them check it out. Thanks!
BigCat09
07-14-2012 02:08 PM
