Zzp IC pump
Zzp IC pump
I happened to come across a video on YouTube where someone was using the zzp ic pump. Anyone else on here have any experience with this pump?
https://zzperformance.com/collection...r-pump-stage-1
looks like a better flowing pump than the Bosch unit. I'm in the situation of replacing the XKR pump as well. The problem with the Bosch unit is that you need to get the power connector and maybe some custom brackets. The ZZP pump you can also purchase the power connector and the mounting bracket.
Looking at the specs its drawing about 6A of current at 14.4volts so the stock wiring should be able to handle the current draw.
The XKR IC pump is protected with a relay and 15A fuse.
Let see if they are willing to send it down to Melbourne Australia.
