Alpine Ex-10 online for under 50.00........
just letting you all know there is a special on them right now.....this is a pretty cool unit if you are looking for an add-on unit for an ipod and bluetooth.....
http://www.alpine-usa.com/US-en/prod...hp?model=eX-10
on ebay:
http://cgi.ebay.com/Alpine-EX-10-Blu...item230428cb4f
on ebay:
well i did the install in my own vehicle,and i must say, even if you only used it for the b-tooth, then it is worth the 50 dollars. Being able to hear the ipod is a plus, although do not expect any kind of great sound quality, it is merely a way to hear the ipod, not anything more. The voice through the stereo system seems to be okay. Especially with the way our windows house the antenna, i was surprised by the fact i could fuly understand the callers and the such. Soooooo for 50 dollars, i have to rank it pretty it high. Now for the retail price of 200 it wouldnt rank as high, although the bluetooth is the only reason that i really wanted it for. Look at the ipod charging/listening as a bonus.
And yes iut will work with any stereo
Yes, the hardwire simply replaces the FM modulation.
I actually put the screen flat, no bracket....to the upper right hand corner of the center console, then ran the main line under the dash piece and installed the main unit directly under the radio. Bluetooth works great actually when transmitting. HOWEVER, since my new office is 4 blocks from Alpine's offices, i may try to see if i can grab the direct unit to go into my antenna section. Then just run a switch somewhere to activate it. At this point im on the fence as to do a full install or just replace the headunit. I saw your pics and it made me want to yank everything out and do a full blown install.
Well If you want, you can practice on my car. All that's done so far is the front speakers and the D3. Still need to run wires, setup amps, I've got a BUNCH of stuff here, I need to pick and choose through the collection to decide what I want. Just waiting for it to warm up a bit. I have a garage but it's not heated.
Take a pic of where that screen sits if you have a chance. What did you use to mount it? Velcro / double sided tape?
The unit work great since the signal is feed directly to the radio before the outside stations can distort the signal from the ipod.I doubled faced the monitor to the dash with a 3M removable tape.I hide all the wiring under the console,all you see is 4inches of wire going to the monitor.Sorry no pics.
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
Fletch44
09-28-2015 02:21 PM
