1995 xj6 growling from underneath.
Difficult one for anyone to advise on a noise,but i have a annoying growling noise coming from somewhere.Originally i was convinced it was exhaust related after changing one holed back box and the cat which had a huge crack in it.
The noise is still there,it comes on at about 2000rpm under load and goes at higher speeds,cant get it to make the same noise when standing idleing.
I have removed heat shield as this was loose and flapping freely.
It doesnt sound mechanical but cant be sure.
Has anyone come across the same problem.
Cheers for any advice mark
Can it be that bad wheel bearing making noise may be the only indication of this type of problem. Sort of the same thing with my front wheel bearing! It went from minor hum to a roaring growl on the same day (around 30 miles total). The ride was still smooth and there was no wobble, even when jacked off the ground. The problem wasn't confirmed until the bearing was actually removed.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
