95xj64.0eng AC Fault codes: 11,23, 32, explanations????
ok, after along weeknd of troubleshooting this is what i came up with with help from "xjrguy" fault test. My Ac climate control panel displays these after runnign the test:
#11: In-Car temperature Sensor? on these x300 is that the small sensor on drive side kneeboard under the smal cointray??
#23: Refrigerant Dual pressure switch:
A. refrig-low
B. refrig dual presssure swtich:
1. open circuit, high resistance or short cicuit to B+ voltage
C. high engine temperature in high amibent temperature
#32: Right fresh/Recir feedback otentiometer sensing (wiper) circuit fault
A. opencicuit, high resistance or short cicuit to b+ voltage, short circuit to grd.
ok need help you electronic guys been longgg time sense mess with elcectronics, USAF(com/nav repairman) is some of these things "plug and play"" type electronics?????????? or do i got to break out teh soldeerign iron??
geno
95 xjr
A. refrig-low
geno
95 xjr
Electronics are all about testing/validating the circuit - it's not a guessing game. Test the circuit - is it within spec?
caldercay, dont have manuals, idea where to get some?? I'm going to test the freon again, but geez, ijust evac and repairs, leakign service pots about 1.5 maybe 2 yrs ago, also no evidencie of oily residue aroudn anything, all looks very clean, but going to start with that, then maybe check out the 2 wire binary switch, on the ac line right before it goes into firewall... thx for all your help, will eventually get it narrowed down, slowly but surely
geno
1995 xj6 186k and going strong
geno
dmatthewman
09-30-2015 10:10 AM
