ECU Location
ECU Location
I wish to find the location of Ecu, The engine keeps going into limp home mode, One fault Coil pack D, This has been Changed as have all plugs Drives Great but suddenly comes up with same fault, after several closer inspection of a common reason I observed it only happen after rain the vehicle is parked at home on the drive 15% slope. The abnormal weather as meant the problem is rare and only after a shower and only after the vehicle has been driven and then restarted. I now believe water is getting in somewhere. thank you in anticipation
The following 4 users liked this post by AlbBolivar:
AlbBolivar is spot on. There is a picture in this thread.
https://www.jaguarforums.com/forum/x...u-x300-118790/
HOWEVER - your heading/signature says 2000 XJ8. If that's what you have then you are in the wrong forum. This information is for 95-97 X300.
For XJ8 I think the ECU is under the bonnet on RH side near bulkhead (but it's a long time since I owned one so best to ask in that forum).
Thank you for your advise I was in wrong forum and I located on Left hand side behind kick panel
rominempire
28
10-08-2020 10:39 AM
