Fuel filter location? 97 VDP
Old 05-12-2008, 02:27 PM
johnsjag's Avatar
Default Fuel filter location? 97 VDP
Hello there. I just recently bought my first Jag (97 VDP) and have done a fair amount of maitenence on my past cars and am hoping to do the same on this one (with some help from the experts!) I have a new fuel filter to put on the car but can's seem to locate where the fuel filter is on these cars. Sorry if this sounds a little amaturish but any help would be greatly appriciated. thanks.
Old 05-12-2008, 02:59 PM
ken@britishparts.com's Avatar
Default RE: Fuel filter location? 97 VDP
Under the car on the frame close to the passenger side, rear tire. Follow the fuel line from the tank to the filter.
Old 05-12-2008, 03:50 PM
johnsjag's Avatar
thanks ken. Any tricks on this car or is it just a straight unscrew the old one and replace?
Old 09-15-2014, 08:21 AM
Nemax's Avatar
I am trying to get a tool to release the fuel lines to the X300 tank, jd203 I believe but have not found a supplier. Does anyone have suggestions please?
Old 09-15-2014, 09:32 AM
b1mcp's Avatar
You don't need a Jaguar special tool for this. It's a common connector type. Just search in ebay for "Fuel Disconnect Tool" and you'll find plenty of options. For example
Lisle 37000 AC Air Conditioner / Fuel Line Disconnect Tool - GM, Ford, Chrysler | eBay
Old 09-15-2014, 10:22 AM
aholbro1's Avatar
Received 1,643 Likes on 1,068 Posts
And a poncho for the fuel shower you are about to take.....
mgb4tim (09-15-2014)
Old 09-15-2014, 11:32 PM
Nemax's Avatar
Thank you for the info. Much appreciated
Old 09-22-2014, 10:17 PM
Nemax's Avatar
x300 I am having major problems getting fuel lines out of the tank. Seems someone has been in there before and the return line is bent so no room to get the disconnect tool in and the outlet pipe has one of the spring clips bent outwards so the disconnect tool can not go in. I am wondering now if the best option is to simply cut the lines and replace them? Anyone had this situation before?
bamforp
08-14-2024 05:36 PM
Bcrary3
09-12-2021 05:41 AM
aholbro1
08-05-2021 05:02 AM
Sprayall
05-30-2021 08:13 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Fuel filter location? 97 VDP
