garage door feature.....
Old 05-19-2012 | 09:26 PM
1badcat's Avatar
Default garage door feature.....
So on my 97 XJR it has 4 diffrent buttons to control 4 diffrent garage door openers. So how do i program for 2 of mine?
Old 05-19-2012 | 10:13 PM
aholbro1's Avatar
If your openers are rolling code, don't bother.
Seem to recall it was '98 that Homelink switched up to rolling-code-capable. Still, if they are "old" garage door openers, it may work for you. Try a search on "Homelink" to find the procedure if you don't have the owner's manual. It is a push-n-hold combo of buttons - I suspect you can find it on the homelink site.
Old 05-19-2012 | 10:28 PM
Doug's Avatar
In the "Quick Link" thread at the top of the X300 section you can download the owner's manual which should have the programming directions but, as mentioned, it won't work with rolling code technology
Old 05-19-2012 | 10:51 PM
motorcarman's Avatar
Here is some old info for the old systems.
bob gauff
File Type: pdf
Old 05-19-2012 | 11:24 PM
mgb4tim's Avatar
I really hope mine work when I finally get my car home. If not, I'll be fabricating a new overhead console. I'll use a Cadillac homelink module - cheap, easy to mold, and works with rolling codes. Ialso want to add a small lcd panel, 2.5" for a reverse camera-also spoiled by my Prius on that one.
Old 05-20-2012 | 10:38 PM
1badcat's Avatar
sweet thanks man!
99xk8guy
06-05-2023 07:28 AM
Guy-Pierre Boucher
09-16-2015 06:55 PM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 05:03 PM
RaceDiagnostics
09-13-2015 03:22 AM
DuhCar
09-11-2015 11:58 AM
Quick Reply: garage door feature.....
