Hard Starting
The following 2 users liked this post by RJ237:
Don B (05-28-2014),
MountainMan (05-28-2014)
Received 13,108 Likes
Welcome to the forum!
There are a number of things known to cause hard starting. The first one to rule out is the Crankshaft Position Sensor (CKPS). If the tachometer reads 200-250 rpm while cranking, the CKPS may be OK. If the tach reads 0 rpm while cranking, suspect the CKPS is failing.
Low battery voltage is a common cause of poor starting or non-starting, because the Engine Control Module (ECM) will not trigger the ignition if the battery voltage sags below 11V or so while cranking. If you have a Volt-Ohm Meter (VOM) you can check this yourself, although some meters do not react quickly enough to give you an accurate representation of the actual cranking voltage. Most chain auto parts stores will do a basic check of the electrical system for free.
Other likely contributors to hard starting include the Fuel Pressure Regulator (FPR) and Check Valve or Non-Return Valve, which work together to maintain 32-44psi in the fuel rail, and when one or both fails, it can take a while for the fuel pump to refill the rail at startup, and as RJ237 has already mentioned, the fuel pump itself doesn't last forever (it's mounted in the fuel tank).
I'm sure others will offer other possibilities - the list is long, but the CPS and battery voltage are the ones I'd check first for any obvious malfunctions.
Cheers,
Don
MountainMan (05-30-2014)
You got me! And I was doing so well until that last sentence!
I don't recall chiding you or anyone else about mixing CKPS and CPS, only offering Jaguar's own usage of CKPS, beginning with the X300, as a standard to which all of us should aspire to conform! :-)
Good point about the CMP or CMPS, since the ECM uses its signal to establish initial ignition timing. I've read that the CMP can drift out of spec over time, its electrical connector can accumulate gunk or corrosion, and the drive teeth have been known to break, so MountainMan could check for those issues too.
I was trying to avoid my typical laundry list, but while I'm on a roll, basic tuneup items are always worth checking when diagnosing hard-starting: air filter, fuel filter, spark plugs, coil power relay...
Cheers,
Don
The following 2 users liked this post by Don B:
MountainMan (05-30-2014),
sparkenzap (05-29-2014)
Wolfy
05-28-2024 08:06 AM
Thang Nguyen
10-12-2015 01:25 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
