Homelink from XJ8 for rolling code?
Old 10-13-2012 | 07:34 PM
mounty's Avatar
Default Homelink from XJ8 for rolling code?
Hello all, I am hoping the Homelink will work with my garage door, but I am certain my garage door opener, having been replaced just a few years ago has rolling codes, does anyone know if replacing it with an overhead console unit from an XJ8 may work? The console looks identical, but I do not know if the wiring harness is compatible. On top of that, did Homelink add the rolling code technology around 98?
I read on the maxima forum some owners replace the console with a newer unit and wonder if anyone has tried it in their X300.
Old 10-20-2012 | 02:06 AM
Canuck XJR6's Avatar
Hi Mounty,
I read somewhere that if you have problems with the rolling codes of today's garage door openers then you can get around it by approaching the problem in reverse. On some door opener motors there is a button you can press to sync or retrain the door opener to your Jag. I haven't been able to confirm this yet but I'm going to try this method when I have a bit more time next week.
Try downloading your garage door opener manual online and see if this feature is available. (or just get up on the ladder and start pushing buttons...)
Good Luck!
Chris
Old 10-21-2012 | 11:58 PM
mounty's Avatar
Hi Chris,
Thanks. Well, from what my research has shown, the 97 and older Homelink controls are not the rolling code technology, so even if I get it to work once, it will not work once the code is changed.
I just happened to be by a Nissan Maxima forums where they have similar issues and many members got around it by replacing the entire overhead bin with the Homelink control from a new unit with the rolling code technology. I am considering trying that myself, but wonder if anyone has done that already.
Old 10-22-2012 | 09:46 AM
motorcarman's Avatar
The X308 GDO module is completely different and will not plug up directly. You might wire around things but the correct module was available.
I don't know if it is still available.
Here is some info.
bob gauff
File Type: pdf
aholbro1 (10-22-2012)
Old 10-23-2012 | 11:20 AM
mounty's Avatar
Thanks Bob! That is exactly what I am looking for. Now the big question, as you raised already is if the retrofit is still available...
Bcrary3
09-12-2021 06:41 AM
Guy-Pierre Boucher
09-16-2015 06:55 PM
corysansburn
09-10-2015 07:15 AM
TexasCat
09-08-2015 05:36 AM
Quick Reply: Homelink from XJ8 for rolling code?
