Key Remote Fob for XJ6 XJR XJ12 X300
Old 02-27-2014, 04:55 PM
knealy2's Avatar
Default Key Remote Fob for XJ6 XJR XJ12 X300
Not sure if this info has been posted before, but I could find nothing here about it.
Anyway….I could not bring myself to purchase a replacement remote for my XJ6 when I found info that the Saab 900 remote will work just like Jaguar’s.
Wasn’t sure if it would work, so found one on eBay for $20 (SAAB LTQFM433 Factory OEM KEY FOB) and took a chance, and walla! Received today and just finished programming it to the car and it works just like my old one.
Hope this helps someone else out there, I just purchased two more from the same seller!
The following 6 users liked this post by knealy2:
Chattanooga_XJR (06-10-2014), KWalton (11-20-2016), newheart8 (07-22-2014), someguywithajag (08-15-2017), tompullizzi (02-19-2023), uslow (08-15-2014) and 1 others liked this post. (Show less...)
Old 02-27-2014, 07:07 PM
jagent's Avatar
My experience was that neither of my 2 original key fobs had batteries in them when I bought the car. When I fitted new batteries the small indicator lights illuminated on one of them, although very dimly. The other fob showed no signs of life at all. I then spent a lot of frustrating time trying unsuccessfully to re-program the "illuminating" one. In the end I decided to open them up and check the tiny button contact points, which strangely enough appeared less worn in the non-working fob. I removed the points from that fob and soldered them into the "illuminating" fob (you need good eyesight, a steady hand and a fine tip soldering tool for this job! - you can also buy replacement points on eBay). As I was doing this job the car was close by, and the moment I refitted the batteries, presto! the door locks responded. It has worked perfectly ever since. I'm not sure why the good points wouldn't respond in their original fob, unless another part of its circuitry was faulty.
The real point here is that despite advice given in the handbook, disconnecting the batteries for a lengthy period does not necessarily cause the fob to lose program. Mine were non-functional for just over 2 years in my ownership and I have no idea how long they had been in that state prior. Despite this, re-programming was totally unnecessary.
Old 02-27-2014, 07:19 PM
[/QUOTE]
Looks very Van Goghish hahaha
Great tip!!
The following 2 users liked this post by BlackX300VDP:
mgb4tim (06-11-2014), tompullizzi (02-19-2023)
Old 02-28-2014, 08:54 AM
Received 8,218 Likes on 4,955 Posts
Be aware that there are 2 frequencies for the X300 in the U.S.
Be sure to check this before buying or programming.
bob gauff
The following 4 users liked this post by motorcarman:
1 of 19 (02-17-2020), cafe flyer (02-25-2021), tompullizzi (02-19-2023), uslow (08-15-2014)
Old 06-10-2014, 04:17 PM
annamiata's Avatar
knealy2, Does Your 96 Jaguar had a VIN number higher than this VIN 759614 number? I am going to follow your lead but I want make sure the Saab 900 LTQFM433 fob works with 1997 XJ6.
Old 06-10-2014, 04:43 PM
sstartss's Avatar
Regarding the two frequencies.
I talked to Jag dealer in Scottsdale, AZ and they said that if you have a American version of the Jag, their fobs were all set to 315Mhz while all of the UK versions use the 433Mhz, hence the two frequencies.
Old 06-10-2014, 08:37 PM
TopHatChef's Avatar
My 1997 US Jag runs on the 433Mhz. If I recall correctly '95 and '96 cars used the 315Mhz, while '97 models used 433Mhz, but '96 VDPs also used 433Mhz (less sure about that last one).
Old 06-10-2014, 09:18 PM
The TSB that I uploaded is for the NORTH AMERICAN MARKET!!!!!!!!!!!
I got the TSB from Jaguar when I worked at the dealer.
THERE ARE 2 FREQUENCIES!!!!!!!!!!!!!!!!!!!
Jag dealer in AZ. is WRONG.
The sure way to know what frequency you have is to remove the SLCM and read what is on it. People can change modules, especially on cars this old.
bob gauff.
The following 2 users liked this post by motorcarman:
cool (06-16-2014), tompullizzi (02-19-2023)
Old 06-10-2014, 09:25 PM
annamiata's Avatar
I just bought a used 315MHZ for 1997 xj6 and it did not work. The reason I asked the question earlier to Knealy 2 with his 1996 so I potentially buy the cheaper Saab fob. There are no American version or England version. Short wheel base with VIN number higher than VIN 759614 uses 433Mhz. For sure all shortwheel base 1997 and maybe some 1996 use 433Mhz
Old 06-10-2014, 09:30 PM
Chattanooga_XJR's Avatar
Just like politicians and lawyers, never ever ever believe anyone at a dealership.
Old 06-10-2014, 10:07 PM
GatorJoe's Avatar
From all this I've gleaned that my early '95 X300 has the 315Mhz system, right? I need to get a key fob.
Old 06-11-2014, 07:31 PM
annamiata's Avatar
yes 1995 uses 315mhz
Old 06-15-2014, 03:38 PM
RJ237's Avatar
Received 2,819 Likes on 2,246 Posts
My Saab remote came yesterday and I programmed it today. $19.95 including shipping from Keyless King on ebay. It even had good batteries.
Old 06-15-2014, 08:23 PM
annamiata's Avatar
was it for your XK8 or 95 XJ6?
Old 06-16-2014, 05:31 AM
RJ237's Avatar
The XJ6, but I think both cars are 315 Mhz, so I may buy another and try it on the XK8.
Old 06-16-2014, 06:45 AM
Satterfield's Avatar
I NEED instructions on how to program one for a 1997xj6 vdp L, Satterfield
Old 06-16-2014, 08:26 AM
RJ237's Avatar
The following 2 users liked this post by RJ237:
ronlaw61 (07-20-2014), tompullizzi (02-19-2023)
Old 06-21-2014, 10:34 PM
superchargedtr6's Avatar
Ordered the Saab remote for my 97 XJR, that was missing the remote(s). Today, tried following the procedure given for programming it, and never could get the chirp spoken of. Can anybody give me a better tip? Thanks!
Old 06-21-2014, 11:05 PM
AlbBolivar's Avatar
I just went outside just to put my xjr in learning mode. At first it wouldn't work but are you making sure all doors/trunk are unlocked (turning key twice to unlock)? After I unlocked all doors/trunk I was able to put it into learning mode. That's as far as I got since I haven't ordered the key fob
Old 06-22-2014, 10:44 AM
I thought I had, but I will try again. I actually got in the car, shut the door, and tried it. Think I need to leave the door open? Maybe the interior lights need to be on?
Quick Reply: Key Remote Fob for XJ6 XJR XJ12 X300
