No ignition lights and car wont start after removal of clock
Hi guys' find myself at a loss again. I removed the digital clock to send it for repair put everything back together now the car won't start. ER comes up on the centre console and bleeps, there are sometimes ignition lights and sometimes there is not. Can't understand it i was very careful not to pull any wires but guess i am just lucky. Any ideas?
I think you have two issues here.
The ER and Bleep is from the Heat/AC Control unit self test. I think there is a signal from the clock to the control unit so it is just protesting at that signal being missing as you have removed the clock.
The No Start is a different issue. You haven't explained what you mean - does it turn over and not start or just do nothing - reading between the lines I think it's the latter. Have you checked battery level? Did you have lights on or key in ignition for a long time while you were working on the car? Battery may have discharged.
shawy (04-26-2014)
Hi' thanks for the reply. Sorry about the explanation, yes you are right the car does not turn over. The lights on the dash sometime come on and other times do not, when they are on and i turn the key it just makes a clicking sound that seams to come from the side of the gear selector which does make the noise of a flattened battery. I will try the battery tomorrow. Thanks again. Regards Wayne
Received 13,108 Likes
Brendan's question about the battery is a good one. Another possibility, if you did not disconnect the negative battery cable while removing the clock, is that something was shorted and a fuse was blown. I'm about to run so I can't look at the schematic right now, but off the top of my head you might check fuses related to AUX circuits, Ignition ON Relay, etc.
It might also be worth jiggling the gear shift lever to ensure that it is fully seated in Park, and if that doesn't work try starting the car in Neutral to see if the Park-Neutral switch is misbehaving.
Cheers,
Don
shawy (04-27-2014)
Hi again guy's, thanks for the replies. What a fool i am, forgot that before i disconnected the clock that i had replaced some bulbs. Yes you guessed right tested them and forgot that i had left the lights on while i was disconnecting the clock, hence battery dead. Fired her up this morning first turn. Not put all the console back together yet while she runs for a while so fingers crossed that i haven't created any more problems. Thanks again. Oh and does anyone know where to get a replacement head lining , mine has the normal old woman problem of sagging.
It's reportedly not a bad DIY. I planned to do mine last summer but only got as far as cutting a small sample out (from pax side near overhead console, so I can't see it from driver's seat) and sent off to a supplier for color match. By the time I got a response, they had shut down for a month or so to move to a new shop, then I got otherwise busy. Still plan to do it, hopefully within the next month or so, and will post pics. Meanwhile, there is a nice how-to on an X308 on one of the headliner-material-supplier's websites. Have lost the link currently, but have posted it several times in the past.
Cheers,
Don
Welcome to Jag-lovers - Members Photo Viewing Page
shawy (04-28-2014)
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
SingBlueSilver
08-27-2015 02:20 PM
