No lights, no instrumentation, no crank - security?
This morning, the door would not open readily, I had to jiggle the handle while turning the key right to get it opened.
Then, when I tried to start it, there are no crank attempts at all.
Could this be dead battery or security feature engaged?
Checked the battery level, and it measured 2.3V
I have posted a picture of how I took measurement [red arrow is the 12V and blue arrow is what I used as ground].
1. Looks like I have to use a jumper from another car. What is a good location to clip the ground portion of the jumper cable?
2. The car has been sitting for a few days. Is it necessary to disconnect the battery when it is going to be driven for a while?
Received 10,916 Likes
Obviously you should have full battery voltage at that junction post. That is, the reading there *should* be the same as what you have at the battery, perhaps minus a tiny voltage drop.
So, almost certainly your battery is dead. Way dead.
Or you have a supply/wiring problem between the battery and the engine bay.
So now you have check voltage at the battery itself and, if sub-par, take action as required.
When/if you determine the battery is good....and if you're still having problems that require tracing out.... you can then check for voltage at the various downstream junction posts.
Selsoft (07-05-2013)
I cannot get the trunk open, it looks like I have to jump start it from the engine bay +ve connection and some ground. Do you know of a safe ground in the engine bay?
This time, everything is working. I will jump start at the battery next time, good advice, thanks.
rsa760041
23
09-25-2015 01:33 PM
joesoap
09-10-2015 01:09 AM
