power steering problem
Received 10,906 Likes
Couldn't hurt to replace the fluid and bleed the system. The correct flluid is Dexron III....not sure what Cool had in mind for an upgrade.
There's always the posibility of an electrical malfunction. The steering control module takes a vehicle speed reading from the instrument cluster (which gets its reading from the left rear wheel sensor) and adjusts the assist according the road speed. Maybe, just maybe, you have a module problem? <shrug> Sometimes solid state module act up when they get warm.
Not much help, I know.
If you have a shop manual I'm sure there are some circuit tests ......
Sorry
Sorry
If in case it is indeed steering speed control module it is located on the lower A pillar left driver side (US) take out the plastic cover and you will see and have a full access to the servo module which controls the stiffness due to speed reading. You can try to test it by using an ohm meter to see if the reading kicks up every time you turn the steering even at a stand still, another possibility is you might have to purge the system if in case you have opened up the system before.
by the way when i mention upgrade of fluid i meant changing it if it was not the correct grade.
Guest
Posts: n/a
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Hello cemreis,
I have still the same problem, when the car is cold, the power steering works fine, but after a couple of minutes, the power steering works very hard.
I've changed the whole fluid with dexron 3 and still the same problem.
The question is, how can i kwow if it's the power steering pump, or the steering box/rack?
Many thanks
Steffen
Many thanks
Steffen
Guest
Posts: n/a
There is a valve inside the pump. When the fluid heats the valve stucks and power steering fails. The repairman opens the pump fixes the valve but in 2-3 minutes it stucks again because of the heat. Mow they're trying (since 1 week) to find the cause of the over-heating. We checked everything, box, cooling device. No reasons yet. If we find out something I'll inform you.
