X300 not start
X300 not start
Hi guys i have a 1996 X300 it was starting fine up until last week. I started it friday and everything was fine saturday morning it turns over but just wont fire start!! I suspect a fuel blockage, located the fuel filter but finding it awkward to remove.
Any help will be much appritated as its got its mot in a week!!
Kind Regards
Dave
Kind Regards
Dave
First and simplest check is the battery. Anything below optimum power can cause your car not to start. Have you tried a jump start, connected to the battery, not the terminal under the bonnet.
Before going in at the deep end and removing the fuel filter, check for a good spark on each plug. Removing the filter is a bitch of a job, inaccessible, with corroded pipes, nuts and connectors doesn't help.
Others will chime in.
aholbro1
08-05-2021 05:02 AM
