X300/X308 suspension bush interchange
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Does anyone know what bushes will fit both models?
Anyone who has been to the powerlex site will know that they seem
very confused as to where the X300/X308 demarcation points are.
They have two overlapping sections for these cars which does not inspire
a great deal of confidence when selecting parts:
Powerflex - Performance Polyurethane Bushes
Have you tried looking on the www.jaguarclassicparts.com website. This shows all the OEM part numbers, so that you can easily see which bushes are common between X300 and x308 and which are different. For instance the front top wishbone bus (CBC5523) is common to both X300 and X308. This is the bush which I have replaced with a custom made sealed phosphor bronze bearing in order to eliminate all non-rotational movement in the joint.
However, I am more concerned about situations where the numbers are different, but in fact the parts fit.
What's availabilty on those bronze bushes, and are they harsh?
