XJR stopped, transmission light is on, won't start
Hello, I have an issue with my 1995 XJR.
While driving my engine suddenly stopped and the transmission light appeared. I tried to start it again but it only cranks. Then I tried to restart the computer by removing the battery terminals and after putting them back again the car stopped cranks as well. I tried to press the crash switch but it didn't help. The fuel pump is working fine as I can hear it running, it has fuel, the battery is OK. I, also, move the gearshift on Neutral and tried to start the engine - nothing again.
When I turn the ignition on, all the lamps turns on for the check and after turning off, the transmission light appears again. After trying to run the engine the SRS Air Bag light appears, but nothing else happens.
I will appreciate any suggestions and help related to the problem.
Thanks in advance.
Thanks in advance.
Yes, I am sure for the battery. By the way, I didn't have the chance to exhaust the battery, because after two attempts to start the car, I restart the computer by removing the battery terminals, after which it stopped cranking.
Hope I'll start the car soon, because this was not in my plan. I have just bought a refreshing kit for the supercharger ...
sparkenzap (05-20-2014)
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
