03 XJR-How to remove the coolant crossover pipe
Old 08-04-2011 | 10:14 PM
Viapa's Avatar
Default 03 XJR-How to remove the coolant crossover pipe
Master Tech. I'm in the process of removing the upper supercharger pulley but don't know how to remove the coolant crossover pipe. What are the steps for removing the coolant crossover pipe on my XJR?
Old 08-05-2011 | 08:20 AM
jimlombardi's Avatar
Default XJR Engine Diagram
Hello
Here is an Diagram of a XJR Engine showing Supercharger and Cooling componets (to maxiumize the thumbnail image - put your mouse pointer on the image then double click your mouse):
03 XJR-How to remove the coolant crossover pipe-outlet-pipe-assembly_page_1.jpg
You might be able to point out the part on the diagram that you are trying to remove.
Jim Lombardi
Old 08-05-2011 | 12:34 PM
Viapa's Avatar
Originally Posted by jimlombardi
Hello
Attachment 12161
Jim Lombardi
It is the pipe that goes across the supercharger snout. How many hoses do I need to connect and how many bolts do I need to remove.
Old 08-05-2011 | 12:40 PM
Viapa's Avatar
Disconnect*
Old 08-05-2011 | 12:44 PM
Viapa's Avatar
The pipe in between arrow#6 & arrow#7.
Old 08-05-2011 | 06:50 PM
Hi
Update: I created a new thread for the Supercharger Removal and Install.
I thought maybe other forum members might need it in the future and putting it in a separate thread will make it easier to find later.
https://www.jaguarforums.com/forum/j...f-files-58889/
The components between the reference pointers 6 (Supercharger unit) and 7 (Supercharger pulley) is Coolant Outlet Assembly per JTIS that includes the Coolant Outlet Duct and Termostat Cover -
the JPEC calls the assembly - the Outlet Pipe also lists the components as the Thermostat housing (Part# AJ83968 or AJ81981 depend on engine number) and Thermostat cover (Part# NCC2245BC).
Here is two diagrams of the same assembly I copied into this JPEG file from the JTIS and JEPC (you may want to use the browser zoom level up to 150% to view this JPEG):
03 XJR-How to remove the coolant crossover pipe-outlet-pipe-assembly_page_2.jpg
Do you want the instructions just to remove the Coolant Outler Assembly or the entire Supercharger?
Jim Lombardi
Old 08-07-2011 | 07:17 PM
Viapa's Avatar
Hi
Attachment 12164
Jim Lombardi
The Coolant Outlet Assembly.
Old 08-07-2011 | 10:50 PM
Hi Vipa
The Coolant Outlet Assembly consist of 2 parts - the Thermostat Housing Cover and the Coolant Outlet Pipe.
Here is the PDF on the Thermostat Housing Cover showing parts diagram:
https://www.dropbox.com/s/pr40evamr6...20Cover%29.pdf
And the PDF of the Coolant Outlet Pipe - removal/install instructions with illustrations:
https://www.dropbox.com/s/n967ibdmxf...er%20R%26I.pdf
Jim Lombardi
1100me
07-24-2023 06:10 PM
aholbro1
08-05-2021 05:02 AM
Daim
11-28-2016 09:28 AM
1100me
09-07-2015 06:26 AM
Jaguar Forums Editor
Jaguar Press release
09-04-2015 09:18 AM
Quick Reply: 03 XJR-How to remove the coolant crossover pipe
