2000 jaguar xj8 4.0 no start problem
found oil in spark plug wells, so decided to change valve cover gaskets and look at 2nd tensioners. Got wrong size gaskets and had to reorder, so had valve cover off for 5-6 days. 2nd tensioners looked good and did not replace but had loosened caps on passenger side exhaust cam, found cam would not move, possibly due to oil tension. Cam did not move as I marked location in several areas and used plastic ties on chain and sprocket. Put everthing back together, and not really thinking about stuck cam, as car ran perfectly before, I started engine. It ran for only a second or two and died. On restart got restricted performance in red. REmoved valve covers again found no movement on cams all my marks the same and cam flats still in line on both cylinder banks. Timing chains are all tight and no sign of skipped teeth. Thought cam or crank sensor caused fault, but spark plugs have good spark. Engine hand cranks and can see cams revolving. Did compression test on all cylinders average was only 40 PSI. My local mechanic wants to pull radiator and serpentine belts and check timing, as he thinks no valve damage ( no noise when engine is cranked plus engine didn't run or move cams to do damage), sensors not bad , so timing is his last guess. I don't think timing is the problem. So what is next?
Received 6,323 Likes
Take a look here https://www.jaguarforums.com/forum/s...etarded-67385/ there are other threads also.
aulbertc (07-24-2012)
Believe me we've been over it, many many times. I think sensor problem, my mechanic now thinks timing and Ford dealership ran compression test and says valve damage, still wondering whose right, and how to determine problem for sure. Thanks
Hi
Here are a lot of forum threads that mention P1642 being recorded and related to the TB (Throttle Body).
It's wire connections (cleaning the wire connections) or the need to rebuild/replace the Throttle Body (both rebuild/replace are expensive).
Here is a PDF file I created from forum member Gus DIY on Throttle Body plugs (connectors) - Photos and instructions including info on cleaning of the plugs.
jagrepair.com ThrottleBodyPlugs.pdf
Also there is TSB on TB connectors - TSB 303-58 (Throttle Position Signal) harness connectors mismatch
Issue:
On some 1999-2001 XK and XJ vehicles within the above VIN ranges, with AJ-27 engines,
Diagnostic Trouble Code (DTC) P0121 (Throttle Position Signal) may be present. A possible
cause is a mismatch of electrical connector terminal materials between the Throttle Position
Sensor (TPS) and the wiring harness electrical connector (gold terminals on the TPS and tin
terminals on the wiring harness).
Gold terminated cable LNG 3956AA 4
Here is the TSB 303-58 attachment:
TSB 303-58.pdf
Jim Lombardi
Technical Bulletin 303-58,
On a customer complaint basis only, install new gold terminals into the TPS wiring harness.Issue:
Parts Information:
DESCRIPTION PART NUMBER QTY
Convoluted tube LST 6754AA 1
TSB 303-58.pdf
Jim Lombardi
The P0102 - might be a MAFS (Mass air flow sensor) issue - might need to clean the Air Box or replace the sensor.
P0112 - has to do with IATS (Intake air temperature sensor).
I found a DIY on Max Performance Cars forum (it was created by one of its forum members) covers cleaning MAFS (also has IATS information):
Here is the DIY PDF file (lots of photos and instructions) download:
Free Cloud Storage - MediaFire
If download not working then try this one:
Cleaning.XK8.Throttle.Body.MAFS.and.Part.Load.Brea ther.pdf
Cleaning the Part Breather by using a drill that is also covered in this DIY PDF is something I personally would not try (in the process I would probably end up destroying it).
Jim Lombardi
Jim Lombardi
Terrance Williams
08-26-2015 11:50 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
