2000 XJR Turn Signal have gone quiet?
There is a small speaker in the steering column that generates the clicking sound. If I recall correctly, another poster some time ago allowed as how it is a real bother to replace - haven't done so myself.
________
HotCummers
________
HotCummers
This speaker also makes the door chime if you leave your keys in the ignition or leave the lights on and open the drivers door. If you still hear the chime then it's not the speaker. If you don't then it time to replace the speaker. Doen't look too bad. I have mine all pulled apart right now as I am replacing my turn signal switch. Pull off steering wheel column covers, air bag, then steering wheel, then it's right there. Maybe 30 min job. Just make sure the steering wheel is fully extended and all the way down and make sure you disconnect the battery aftre that.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
