2003 XJ8 Transmission Fluid & Filter R&I
Hi
I am posting this new thread because I could not find another thread with instructions & illustrations that covered 2003 XJ8 Transmission Drain/Fill and the R&I for the Transmission Pan and Filter.
Here are 3 PDF files I extracted from the JTIS Repair CD:
2003 XJ8 Transmission Fluid Drain & Fill.pdf
2003 XJ8 Transmission Fluid Pan R&I.pdf
2003 XJ8 Transmission Fluid Filter R&I.pdf
There maybe a couple of other threads describing how to do the Drain & Fill without using the PDU device. I will try to find and include them at a later date.
Jim Lombardi
Jim Lombardi
The following 4 users liked this post by jimlombardi:
Hi
I found another thread with this information and more that I created for 2001 XJ8 (5/20/2001) -
https://www.jaguarforums.com/forum/x...-cd-faq-54942/
It is also listed in the FAQ sticky Thread - use the Internet Explorer (Edit then - Find on this Page) to search for ZF5HP24 in FAQ sticky Thread.
Jim Lombardi
Jim Lombardi
wrd0225 (06-08-2017)
Hi
I found a post that forum member "test point" (Tom) describes a way to fill the fluid to capacity without using the PDU device (See post# 6):
https://www.jaguarforums.com/forum/x...ns-help-36256/
Jim Lombardi
Jim Lombardi
aholbro1
08-05-2021 05:02 AM
OkieTim
09-08-2015 04:48 PM
Wes Steenrod
09-06-2015 06:52 PM
