98 XJ Fuel injectors & Fuel Rails R&I FAQ
Old 12-26-2011 | 08:12 AM
jimlombardi's Avatar
Default 98 XJ Fuel injectors & Fuel Rails R&I FAQ
Hi
Here are 3 JTIS extracts that cover depressuring the Fuel system, Fuel Injectors R&I, and the Fuel Rails R&I:
98 XJ depressurizing fuel system.pdf
98 XJR Fuel Injector R&I.pdf
98 XJ Fuel rail R&I.pdf
Also here is a JPEG file of the JEPC (Jaguar Electronic Parts Catalog) page showing the 98 XJR Fuel injectors and Fuel rails parts list and diagram:
I had a special request from one of the forum members and that is why I created this new thread.
Jim lombardi
The following 3 users liked this post by jimlombardi:
adriaxj8 (05-12-2012), Cadillac (12-27-2011), gocallahan (12-26-2011)
Old 12-27-2011 | 04:08 AM
Cadillac's Avatar
Thanks , I will add these files in the FAQ page
Old 05-07-2012 | 04:59 AM
JKo's Avatar
JKo
I'm looking at the XJR fuel injector R&I document... should the loosening of the nut (2) in step 3 really give enough clearence to remove the injectors that are located below the charge coolers? The gap between the cooler and valve cover looks rather tight.
Bradley Chambers
39
02-11-2016 10:55 AM
SD96XJ6L
09-25-2015 10:53 PM
DaveInVA
09-25-2015 04:43 PM
reb1999
09-25-2015 10:00 AM
Bcrary3
09-11-2015 10:36 AM
Quick Reply: 98 XJ Fuel injectors & Fuel Rails R&I FAQ
