Which brand of coolant is correct for 99 XJ8
JTIS says I should use coolant of this spec ESD-M97B49-A for my 99 XJ8 (Vin 876xxx). However this does not directly translate into the brands available with my local suppliers, eg Halfords, Sureparts etc (UK).
Having looked at a sample from the header tank the current coolant appears to be yellow, actually, you could say it has the colour of urine. Thankfully not the smell.
I know you should not mix different types so which brands of coolant available on the UK market would be correct for my car ?
The yellow stuff in the car would have been supplied at on of the previous main dealer services.
Received 6,338 Likes
It looks like Halfords own brand fits the bill.
Halfords | Halfords Advanced Antifreeze & Coolant Concentrate 5 Litres
I have the same problem....had an emergency on the weekend where it overheated so filled up with what I had (VW Quantum antifreez with similar required properties) with a view to flush and refill soon. Also, try this thread for a more long term solution:
https://www.jaguarforums.com/forum/x...olant-q-35038/
Gavin.
Gavin.
Found this Ford product which is "Yellow". http://www.fcsdchemicalsandlubricant...oling Products Antifreeze/Coolant Concentrated&category=A/C and Engine Cooling Products
Whats the chances that yellow Spec. WSS-M97B51-A1 is the same as D542 ? Any way to check ?
Wolfy
05-28-2024 08:06 AM
