Can Fuel Pump fail intermittently?
Hey Guys,
Twice in the last few weeks the 01 VDP 94K after being driven for approximately 30 minutes, followed by sitting at idle in park for 5 Mins has studdered and stalled. Immediate multiple attempts to re-start produce very rough idle, no response to pedal and subsequent stall.
First time - after a few hours it started and operated normally, although the car was not driven.
Yesterday - I kept reproducing the same result with one 10 minute period of normal operation (in park) followed immediately by the same rough idle and stall.
I attempted to turn the key while listening for the pump and heard it once out of 7 - 10 attempts. (Once pump is primed will it cycle every time key is turned, or only after a period of time?).
Car had fuel filter replaced yesterday morning (while doing tensioner job) so this has occured both prior to and following filter replacement.
I swapped one relay in the trunk - but had no change in symptom.
Question: can a fuel pump fail intermittently? And, any other thoughts would be helpful.
Thanks in advance.
Thanks in advance.
2000, 308, failing, fuel, intermittent, intermittently, jaguar, location, locationreload, mk2, mustang, primes, pump, working, xj
