Can I shave-down the valet key into a regular key?
It looks like the only difference between the two is the "shoulders" at the end; can I just shave-down the sides of the valet key-end to have the same shoulders and it will work like the regular key?
Is there any difference in the electronic-transponder for the valet key?
Basically, I have no use for valet mode and need an additional key that will let me open the trunk/fuel-door.
There was a thread on this but I can't find it.
Here are the two keys
To mod your valet key carefully file the tip to 4.5 mm (0.175") diameter for a depth of 2 mm (0.08").
Take the same amount off both sides of the key.
My two master keys measure 4.5 and 4.4 mm at the tip so a bit under 4.5 mm is OK
The following 3 users liked this post by steveinfrance:
Jzar
09-27-2015 02:55 PM
