check strap / door panel removal
I will have to remove the (drivers side front) door panel to replace my annoying check strap (that dosn't check).
On my X300 the wood trim panel had to be removed due to a retaining screw underneath. I know I will have to remove the door handle escutcheon screw and the door armrest screw. Does the door panel just unclip around the edges after this, or will I have to remove the wood trim as well.
On inspection and looking at the JDHT schematic it appears that the panel is one piece, rather than two separate pieces as in the X300.
Any tips welcome, including how not to mash the plastic strap covers when removing to get to the screws.
Many Thanks
AndyP
Many Thanks
AndyP
Here are directions/illustrations on removing the driver side front door panel:
https://www.jaguarforums.com/forum/a...l-76-34-01-pdf
https://www.jaguarforums.com/forum/a...t-76-34-22-pdf
https://www.jaguarforums.com/forum/a...l-76-47-11-pdf
Here is a weblink to forum thread on replacing the door checkarm - look at post# 6:
https://www.jaguarforums.com/forum/x...w-36075/page2/
Jim Lombardi
Jim Lombardi
The following 2 users liked this post by jimlombardi:
kyle04 (05-22-2013),
WaterDragon (08-11-2013)
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
davidladewig
09-03-2015 06:32 PM
