Climate Control Panel R&I FAQ
Old 01-02-2012, 09:14 PM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default Climate Control Panel R&I FAQ
Hi
Forum member Squish requested a JTIS21 extract on Climate Control Panel(Center Console Switch Module).
Update - added another JPEG file showing the Climate Control Panel taken from JPEC (Jaguar Electronic Parts Catalog):
Here is a JPEG file I created from the JTIS Climate Control System Panel from the Description and Operation section:
Here is a JPEG image I copied from the JEPC catalog of the radio unit that has to be removed to gain access to the Climate Control Panel:
Here are the JTIS21 extracted instructions and illustrations that I put into these PDF files:
This PDF contains instructions on the Climate Control R&I
1999 XJ Door Lock Control Switch 86.80.32 R&I.pdf
2003 XJ Selector Lever Gate Finish Panel R&I 76.25.24.pdf
2003 XJ Foor Console Finish Panel R&I 76.47.26.pdf
2003 XJ Foor Console Finish Bracket R&I 76.25.26.pdf
2003 XJ Audio Unit Housing 76.25.15 R&I.pdf
2003 XJ Climate Control Assembly Housing R&I.pdf
I had to go back to 1998 from the 2003 model year to find some of this R&I information.
Jim Lombardi
Cadillac (01-03-2012)
Old 01-02-2012, 09:53 PM
squish's Avatar
Many thanks!
Replacing the Climate Control display bulb.
Old 01-03-2012, 03:19 AM
Cadillac's Avatar
Thanks , I am adding this topic into the existing FAQ
Jose
03-22-2016 04:59 AM
Chris Hinton
09-24-2015 08:38 PM
al_roethlisberger
09-21-2015 08:07 PM
texaspete
09-10-2015 08:34 AM
tberg
09-07-2015 07:32 AM
Quick Reply: Climate Control Panel R&I FAQ
