Coolant Hoses Parts Numbers?
Old 04-16-2011, 08:24 AM
yeldogt's Avatar
XJRguy -- Very interesting TB -- great information when you need to get to those hoses. I believe one of the technicians on the forum had a quick way to fix one of them?
The most interesting part for me is that now we know the coolant -- Havoline XLC extended life. Also ------ see what Jaguar wanted the service people to do before replacing the older (green) fluid. I believe the change over was for model year 2000. my x300 and first x308 had the green.
Old 04-16-2011, 01:13 PM
That's right, in essence the orange XLC coolant was installed in everything 2000 MY and later. There was a period though, that a yellow [D542] coolant was used. Was a frustrating period, where a lot of folks mixed up the coolants and topped up with the wrong stuff quite often. Take a look at these and you will see what I mean! They should never be mixed.
What a mess it was!
Cheers,
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 04-16-2011, 02:12 PM
yeldogt's Avatar
I guess my 98 VDP was yellow not green -- I remember seeing a lot of my 95 vdp's green coolant -- when the head gasket failed! Thankfully...under warranty.
My memory is that the XJR tales 10 liters -- they are showing it holding quite a bit more? Confusing?
I only purchased 1 5 LT jug -- I thought that you could get about 8 out of the system with a simple drain??
Old 04-16-2011, 06:00 PM
I think the figures you got were from the bulletin describing the flush and changeover. Doing that you have to allow for the large quantity of plain water left in the block. That's why the larger quantity of straight coolant. In the course of a maintenance change, 1 five litre jug cut with water fills you back up, and leaves about half a jug to keep for top ups.
Cheers,
Old 04-16-2011, 10:36 PM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default Hey guys - Coolant Hose Thread - too much Coolant Fluid Stuff
Hi
First I like to say Thank you to xjrguy for the part numbers and their use information in post #2.
I know many members like to discuss Coolant Fluid, but I was trying to keep this thread on concentrated on Coolant/Heating hoses.
The goal was to use this tread as a source of information about Hose sources, part numbers, prices, and DIY on hoses replacement information.
Please do not dilute this tread with other information. I do not mean to offend anyone. But............................................... .....................
A lot of work and time has been expended getting the information and sources related to these hoses.
It gets hard to find the posts that relate to thread's title when there are so many other posts in the thread.
Please start a new thread to discuss Coolant fluid or add to one of many already existing coolant fluid threads.
Thank you for your cooperation.
Jim Lombardi
Old 04-21-2011, 05:42 PM
Default I am replacing Thermostat tower plus its hose & Raditor hoses
Hi Sirjag
I placed an order with Rock Auto Parts this morning. Boy do they have low prices onthese URO hoses. The three hoses:
from Rock Auto Parts totaled about $37 plus $10 shipping
the local auto parts store was about $85 with tax
and the Jag dealership was about $113 with shipping.
NCA2213AC (AJ85313) $1.85 Bypass hose - heater and air conditioning
MNC4505AD $7.28 Radiator Upper hose
MNC4515AD $27.79 Radiator Lower hose
I will get everything installed by my friend/mechanic by the middle of next week. Labor probably will be about $150 for replacing the thermostat tower, thermostat, and the hoses.
Jim Lombardi
Old 04-22-2011, 02:28 AM
SirJag's Avatar
Originally Posted by jimlombardi
Hi Sirjag
Jim Lombardi
Hi Jim,
Great... I'm glad you found their prices to your liking. I like RockAuto... good service and excellent prices. I'm also liking AdvanceAutoParts... super professional and great selection.
My mechanic comes tomorrow. Lots of jobs for him. I need to run out early and get clamps which I forgot. I assume the ones at Ace Hardware are the same at an auto parts store. I was told by a mechanic that the ones used by Jaguar are really one-time use only clamps.
SirJag
Doug
02-27-2019 01:31 AM
KarimPA
09-03-2015 07:32 PM
Busa R
09-03-2015 05:01 PM
Bcrary3
09-03-2015 03:48 PM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Coolant Hoses Parts Numbers?
