Coolant lines - disconnect?
The following 3 users liked this post by motorcarman:
Unless someone has done a lot of work changing out hoses you will probably find one of those tools stored in a fitting on the engine. I think all of the cars were sent out of the factory with one on the engine.
My XJ8's was on a fitting under the throttle body and My XK8's was on the part load breather. Take a good look at all of the plastic tubes you might find one sitting in the fitting.
Don B (03-18-2019)
Guy-Pierre Boucher
09-16-2015 05:55 PM
