Door handle link replacement c/w pics...FAQ
So my door handle link snapped... For over a week I had to roll down the driver side windows to let myself out... Talk about embarrassing....![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
So I ordered a new link/door handle assembly from eBay for $80...
I also went to Harbor Freight Tools to get this:
![Name: DSC04972.jpg
Size: 56.2 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166774d1501277140-door-handle-link-replacement-c-w-pics-faq-dsc04972.jpg)
Very handy for removing trim.
Here is what I did (pic):
RED arrows first:
- remove the screw in the door handle cup, and remove the cup by pulling on the door handle and working the cup out.
- remove the screw under the arm rest
GREEN arrows:
- use a nylon pry bar to pop out the two fasteners holding the faux-wood trim, and then SLIDE is to the LEFT. Don't try to pull towards you or it will snap.
PURPLE circles:
- use the pry bar again on the pin fasteners.
![Name: 2012-01-29_172229.png
Size: 602.1 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166775d1501277140-door-handle-link-replacement-c-w-pics-faq-2012-01-29_172229.png)
This is why you wanna slide the faux-wood insert and not pull it:
![Name: 2012-01-29_173640.png
Size: 601.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166776d1501277140-door-handle-link-replacement-c-w-pics-faq-2012-01-29_173640.png)
Anyways, To remove the door trim itself, first PULL the bottom part out to where you can see all the side and bottom fasteners out, and the trim itself is about 2" from the door, then LIFT the trim UP.
Here is what you'll see:
![Name: 2012-01-29_174713.png
Size: 602.4 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166777d1501277140-door-handle-link-replacement-c-w-pics-faq-2012-01-29_174713.png)
Disconnect the speaker wire, and the yellow connector for the door/windows switches. You can leave the door light wire on as it's long enough for you to put the trim on the floor without the need for disconnecting it.
The door lock assembly and the links.
![Name: 2012-01-29_174930.png
Size: 425.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166778d1501277140-door-handle-link-replacement-c-w-pics-faq-2012-01-29_174930.png)
![Name: 2012-01-29_175154.png
Size: 553.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166779d1501277140-door-handle-link-replacement-c-w-pics-faq-2012-01-29_175154.png)
Was able to squeeze my camera in the door frame pointing towards the lever that the link connects to:
![Name: 2012-01-29_175305.png
Size: 378.4 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166780d1501277140-door-handle-link-replacement-c-w-pics-faq-2012-01-29_175305.png)
Getting ready for this project I had problems finding good (any) pics that would help me visualize what I was about to get myself into. Hopefully this will help others that may run into this issue...
Mike
RED arrows first:
GREEN arrows:
PURPLE circles:
Mike
The following 45 users liked this post by mzs_biteme:
A.J.P (06-21-2017),
ant17 (10-18-2021),
Badbenz94 (10-14-2013),
badger2196 (08-20-2014),
Boomer from Boston (01-29-2012),
and 40 others liked this post.
Received 9,008 Likes
xjay8 (03-30-2015)
The "chicken scratch" illustration below should help explain (I think
![Name: lock_mechanism.jpg
Size: 78.0 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166761d1501277109-door-handle-link-replacement-c-w-pics-faq-lock_mechanism.jpg)
The following 4 users liked this post by mzs_biteme:
Look at this pic again... The aluminum "fins" on the back of the wood trim, slide onto the (black) door handle assembly on either side of the link.
Size: 601.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/166756d1501277097-door-handle-link-replacement-c-w-pics-faq-2012-01-29_173640.png)
One final question: When prying out the wood veneer trim, are the two pop-out fasteners pretty much under where you show the ends of the green arrows? How did you do the prying? Top, then bottom, then top etc. or did you have two pry bars going at the same time? I would be concerned that being just a little off would risk cracking the veneer. Maybe a picture of the back of the veneer trim, showing the fasteners, would help. Thx.
The following 7 users liked this post by mzs_biteme:
Alvin Burns (07-31-2012),
D. Fite (01-30-2012),
David N. Warner (05-16-2023),
Johnny_B (10-09-2016),
Platinum XJR (11-15-2013),
and 2 others liked this post.
I have my door panel off and the cable removed. Do I need to remove the latch assembly(the one connected to the exterior door handle) to replace the cable or can I do it while it's still attached to the door??
Thanks!!
Chris
Nm, you don't. I got it working thanks!!!
Thanks!!
Chris
[QUOTE=mzs_biteme;462053]So my door handle link snapped... For over a week I had to roll down the driver side windows to let myself out... Talk about embarrassing....![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
Here is what I did (pic):......[QUOTE]
Thank you Sir!...This has to be one of the most concise and descriptive posts i have seen in a long while...very well done! ;o)
As I am about to tackle some speaker replacements and a bit of door R&R....this will be most useful.
Thanks once again.
Thanks once again.
Here is an ebay link to the gaskets I just bought, they are the same front and rear so I ordered two sets.
New Jaguar Door Handle Gaket Kit Lt RT Pair XJ6 XJ8 XK8 | eBay
dsetter (11-01-2014)
Seems i can't add my thanks to this great post in the mobile app.
THANKS!
Just completed this last night. As I did not have a replacement cable, I fashioned one up with stranded picture hanging wire. I created an end for the latch/ handle with a 4mm tube with a hole drilled in the side to pass the wire through and a crimped tube the other end against a washer. A rubber grommet on the latch side keeps it in position and allows the free play required for the correct latch operation.
This is a very tedious process.
One point missing from the OP posting is that there is a small spring clip on the catch that is used to retain the cable outer into the latch assembly. Without replacing that, it is possible that the cable could work is way out.
THANKS!
Jhartz (11-28-2014)
