drivers window and sunroof malfunction
G'day Mates!
I have a "new" 99 XJ-8 VDP.
The drivers (only) window does not operate properly nor does the sunroof.
The window will not go up/down although I hear the "click" when I push the button. The sunroof opens but then closes itself after 15 seconds. Same thing when tilted.
I "rebooted" by disconnecting the battery for 30 minutes and all was fine. It did not last long though, within a few hours I was back to the same issues.
I'm hoping someone has some insight into this problem.
Thanks and Cheers!
Tom
tomtomterrific
Jaguar Conservationist LI NY
currently own (2) 99 XJ-8 VDP's
Thanks and Cheers!
Tom
tomtomterrific
Jagman99R (01-14-2011)
Try the "Hard Boot"...
My windows were confused too a few weeks ago. Following Brutal's advise here's what I did.
Disconnect ground cable (- side) from the battery and then touch it to the Positive Post on the battery and hold it there for a few seconds.
Nothing is going to fry and there won't be a spark. This will clear any bad memories by completely depleting voltage in capacitors within the modules.
It worked perfectly for me.
Ken Wolkens
Ken Wolkens
The following 6 users liked this post by Sinister 1:
CB3 (03-13-2012),
haroldleggett (12-27-2018),
Jagman99R (01-19-2011),
Mike Allen (10-20-2012),
retromotors (12-28-2014),
and 1 others liked this post.
I was told by my dealer that the sun roof rails were bent and they would have to order from the Uk after I asked my bank manager for a loan .... ha ha. This did not make any sense to me so I stripped the door panel and removed the window computer. When I saw the warning that this part is programmable the "light" went on. I disconected the contacts, reconected did a hard boot and its been working justfine for the last year or so.
Regards
Gareth
South Africa
Regards
Gareth
South Africa
Hello and this is my first post. I have to say that this forum is really inspirational for self-helpers.
My question is about the "hard boot". Once you disconnect the negative cable from the battery and then hold that same cable to the positive post on the battery (for a few seconds), does this action remove all the prior programming to EVERYTHING? Are there any side-effects to doing this? Do I have to reprogram the memory in the radio, the seats?
Thanks!
Thanks!
Quick call to your local Jag agent - parts dept. Give him the last 6 digits of your VIN number and he will give you the code.
![Icon Rant](https://www.jaguarforums.com/forum/images/smilies/icon_rant.gif)
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
So, as you can see, I would prefer another solution.
If you didn't talk to the parts counter, you will get the response you just stated. If you don't get satisfaction from that dealer, call one of the dealers that participate on the forum. It doesn't matter where you live, this can be done over the phone.
yachtboy (07-26-2018)
Thats a shame about your dealer -- the one I use in NJ is very nice. The parts guys are very helpful.
And the sunroof will reverse if it is not lubed or the wrong lubed is used - the motor has force control.
I still would be afraid to touch that ground to the battery![Icon Look](https://www.jaguarforums.com/forum/images/smilies/icon_look.gif)
Some of that stuff still says Lukas
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
If you have a problem that matches others on the forum. It is the same fix. Window & sunroof problem at same time. Not a coincidence. Computer ties both together. Do the simple hard boot and problem will go away.
This car is not your grandmothers Buick. If te sunroof opens then closes after a few seconds it is a computer problem not mechanical.
Many have done the hard boot and fixed the problem.
Save yourself time & $$ try the fix you read about here 1st. If that doesn't fix it then look at other options.
Hope this helps.
Mark in Destin
Hope this helps.
Mark in Destin
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Just got a chance to try the hard boot and it worked for me.
Didn't have a problem with the radio either.
Never did get a chance to try the dealer again for those codes. I've been busy replacing the upper chain tensioners.
Glad thats done. I just figured I'd give the "boot" a try and it worked great. Thanks, guys!
![Icon Hunter](https://www.jaguarforums.com/forum/images/smilies/icon_hunter.gif)
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken Wolkens
Ken Wolkens
1. Turn Key OFF
2. Remove Negative Battery Terminal from the Negative Battery Post (10mm Wrench)
3. Turn Key ON
4. Touch Negative Terminal End to Positive Terminal End and hold there for 15 'ish seconds (Positive Terminal will still be connected to Positive Battery Post)
5. Turn Key OFF
6. Reconnect Negative Battery Terminal back to Negative Battery Post
NOTICE: On First Start after the Hard Reset, let the car idle for a minute or two without touching throttle. This allows the computers to recalculate the throttle position, etc... Also, the car may drive differently for an hour or so while it's relearning your driving habits.
See Attached Photo showing Correct Short for Hard Reset
NOTICE: NOTHING CONNECTED TO NEGATIVE TERMINAL
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/25085d1350845666-drivers-window-sunroof-malfunction-correct-hard-reset.jpg)
PS: My window stopped two days ago, so I knew I had to do this anyways, and thought I'd post a photo for clarification. Window works fine now.
The following 14 users liked this post by SuperSport:
Auspuff (04-30-2015),
Catenaccio (03-22-2014),
Coventrywood (12-28-2014),
IH60 (10-15-2015),
and 9 others liked this post.
