engine mount
Good day every one and for a long time no see
I dropped off my car for brake work with all new pads and rotors but instead, we found that engine mount was in a very bad condition and on the test drive that engine was about the shake out of my car
but my car "felt" smooth on the road even at the high speed before going to the shop but now ,all the sudden.
![Name: IMG-20120929-WA000.jpg
Size: 62.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/160163d1501265068-engine-mount-img-20120929-wa000.jpg)
![Name: IMG-20120929-WA002.jpg
Size: 67.5 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/160164d1501265068-engine-mount-img-20120929-wa002.jpg)
The left Engine Mount in your first pic is heat damaged and the right one is split.
This is a new one:
The damage to the left one in your pic is likely to have happened as it was being removed. The right one in your pic is worn out.
vincent661983 (10-01-2012)
Are you saying the car handled perfectly before the brake work but was shaking when you picked it up?
This is a new one:
![](https://www.jaguarforums.com/forum/attachments/xj-x308-xj8-xjr-27/24143d1348957785-engine-mount-x308-engine-mount-jpg)
This is a new one:
thank you, GGG
but it was fixed already before I made this post. I was just bit surprised about the sudden breakdown
vincent661983 (10-03-2012)
Received 9,007 Likes
I thank you for your sincerely concern, but that is my "main-man"'s shop,so nothing to be suspicious here.
vincent661983 (10-04-2012)
The following 2 users liked this post by Sean B:
plums (11-07-2012),
a rough and ready test Safi - put the car in gear and press the break pedal rev the engine and see if it moves/twists up off the mount, this only tests the lhs mount though...if you can get a look under the car with a flashlight, the mounts weep oil if failed and it'll be obvious if they're shot.
XJDanny (08-05-2015)
There is a change in Part Number shown by VIN:
MNC7500AA (to VIN 818581)
MNC7500AB (from VIN 818582)
Aftermarket suppliers don't make any reference to this change so it may be a Jaguar supplier or material specification change only.
Safi (11-07-2012)
I know this is little old thread.
Could any help me identify the difference between these two?
and why the price is so different?
SNG Barratt - The Ultimate Jaguar Parts Specialist
Regards
Regards
Regards
Regards
You are correct!
I've contacted SNG and they've confirmed this is the case.
I also did ask if there are any difference, They said "OEM parts have better finish with an improved housing..."
I've ordered after market ones so will let you guys know how it differ from the OEM later!
rusty37
04-05-2020 07:40 PM
Tar
09-06-2015 11:24 AM
