Engine Mount is filled with oil/grease?
Old 01-12-2012, 12:25 PM
JaguarXJR02's Avatar
Default Engine Mount is filled with oil/grease?
got under the car today to figure out what I thought was an oil or trans fluid leak, it turns out the engine mount bushings are filled with some type of oil or grease, and my passenger side one has given up.
I searched and saw lots of threads about replacing it, doesn't look like too bad of a job
Attached Thumbnails Engine Mount is filled with oil/grease?-img_2099.jpg
Old 01-12-2012, 01:26 PM
yeldogt's Avatar
I have not had to replace mine -- So I don't have any direct knowledge of this particular mount --but it is not uncommon to have fluid filled motors mounts.
This come up quite often on the MB forums -- Mercedes has used these for years and often the aftermarket mounts are not fluid filled and do not perform as well.
So know what you are getting
Old 01-12-2012, 03:11 PM
if/when I replace it I will stick with OEM jaguar parts
Old 01-12-2012, 05:59 PM
Received 2,193 Likes on 1,359 Posts
Its filled with purple clothing dye. Cause if you get it on your clothes it will not come out
pass side is super easy, drivers side makes you wish youde never tried if youre in you driveway
test point (01-12-2012)
Old 01-13-2012, 03:50 PM
JWT's Avatar
JWT
JWT is offline
I just replaced my passenger side mount. When putting in a replacement transmission, the purple die Brutal referred to was oozing out of the mount. I suppose when I was tilting the motor and transmission, it started pushing out the fluid. There appeared to be some signs of previous leakage, but I may have aggravated it in my removal and installation efforts.
It sounds like I was pretty fortunate that it was the passenger side, based on his comments about the left side. I am curious about what it takes to replace the left side ( but not that curious!)
The right side was easy, except for getting the nut off the top...that was one very tight nut. I guess it was frozen on despite looking clean and not corroded.
Hope yours is the right side! ( and that my left one does not fail)
cissdm
05-03-2016 06:02 AM
EZDriver
09-08-2015 09:25 AM
tberg
09-07-2015 07:32 AM
Tar
09-06-2015 11:24 AM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: Engine Mount is filled with oil/grease?
