Error Code 1722
The full description from the Jaguar table for P1722 is:
Fault Description
Transmission stall speed failure
Default Action
When fault is detected:
1. transmission adopts limp home mode (5th gear)
2. ECM limits engine power
Possible Causes
1. transmission oil level low
2. selector cable adjustment / installation incorrect
3. output speed sensor problem
4. transmission failure
If there is no other issue that the code is present, there may have been a transient out-of-range signal from the output speed sensor to the TCM at some time.
Fault Description
Default Action
Possible Causes
Gippsland (11-03-2012)
Will P
09-19-2018 08:36 AM
KarimPA
09-27-2015 08:46 AM
