Front caliper problem.
I just replaced all the rotors and calipers with a generic brand, Centric I think, any way it all went smoothly except for the right front. I could not retract the caliper far enough for the new pads.
Needing the car for work, I installed one new pad inboard, and an old one outboard. The shuddering and pulsating pedal is gone but it pulls to the left, something it did not do before.
Any ideas why the piston won't go far enough? I am assuming the mix of pads accounts for the pulling, but I don't know what to do with it. Is the back of the piston flat? Does the rotation of the piston matter?
Rob have you got a piston compressor, it might be just a sticking piston, or seized. Also, did you attempt retracting it with the brake line cracked, you loose a little fluid but it eases the pressure behind the piston.
If it's seized, it's either a caliper refurb or good s/h unit - of which you should be able to get easy and cheap.
Received 2,263 Likes
I retracted it with a compressor and opening the bleed valve. I have bled the brakes since. I confirmed by using a digital caliper that the piston is not retracting as far back as the left front unit.
I suspect a new unit is in order, but since calipers just have a very simple bore and piston, I can't imagine what 's causing the issue.
Received 2,190 Likes
why did you replace the calipers???, they seldom need to ever be replaced unless you dont keep up with 2yr/24k brake system fluid flushes and build up moisture in the system and rust/leakage. If it is indeed a new caliper I would suspect mismachined part or foreign object stuck inside bore.
philwarner
09-05-2015 10:05 AM
