Help - Coolant lines crossed - FIXED
I had my wiper motor replaced today. It seems you probably have to remove the coolant tank to get to that. Am I right?
Anyway, a low coolant light came on on my way home (the bottle was full a day ago; I check weekly). I let it cool down for 4 hours and looked under the hood...the two lines coming out of the front of the coolant bottle (one to the radiator, one to overflow tank) I swear used to be 'crossed' but now no longer are....it looked odd when I bought the car and this is how I noticed it today. The coolant bottle seems to be almost empty now. Is it possible they crossed the lines?
Please can you tell me in plain English what the correct configuration of these lines should be (I tried to do a search as I swear I once saw a photo of it on here). As it stands, the LOWER one on the far left of the bottle (coming out of front of bottle) is now going to the atmospheric catchment tank, and the one on the UPPER right of the bottle (coming out of front of bottle) is now going to the radiator. If what I jut posted is the correct configuration, is it possible they just didn't replace the coolant?
Really appreciate your help!
Scottish Chap (09-14-2011)
Lastly, , do you guys have a diagram or photo of this that I can print?
Thanks so much.
had the same problem with mine. by using a very small flat head screwdriver or a nail press that into a slot and wiggle just a bit. then do the other side. after a couple trys it will come right off. than do the other hose and they just press right back on. also orange coolant. good luck
The following 3 users liked this post by Scottish Chap:
Received 9,011 Likes
KarimPA
09-03-2015 07:32 PM
